S
Supra_Showgirl
·Guest
It seems to me that the more I read about dual voice coils, the more I am confused. I am about to buy a pair of subwoofers and an amplifier, and I want to be sure that I buy a system that matches.
First of all, what are the wiring options for DVC? I know that 4 ohm DVC (which I plan to buy) can be wired so the amp "sees" 2, 4, or 8 ohms. But, what exactly is that wiring? And what is the advantage of running higher or lower? How much trouble is it to find 2 ohm stable amps?
I am buying the amp to match the drivers, which will probably be 4 ohm DVC. If I have a pair of subs, I need two channels, right? Or does it depend on how I wire them?
My main concern is: What are my configuration (sub/amp/wiring) options if I have a pair of 4-ohm DVC subs? I want to be sure the sub and amp match.
The front speakers (currently stock) will run off the head unit, but I may buy a separate amp once I install the speakers I recently bought. I want to keep the amps separate in case I were to upgrade one part.
Sorry this is so long, but I was so confused. I'd appreciate the reply, and I can also be contacted at [email protected] . Thanks!!
