1 - 20 of 33 Posts
i believe it was 21 psi.
very healthy #'s i must say.
that will easily do over 600rwhp on 25+ psi
congrats
Destroyer of Turbos
congrats glad to see people still pushing the envelope! now send in your application to gtepower.com and ill put your car up!
I need pics and a list of mods please.
Way to go!!!!!! :bowdown:
Now that I like.
Congrats.
I can't wait to get to the dyno. I am not sure what Krister is using for EMS but hopefully I can do some nice fine tuning with the MSII and match or even surpass those numbers. :)
475RWHP 449TQ and climing
Discussion Starter · #14 · (Edited)
blackout_89t said:
Now that I like.
Congrats.
With that msII you should be kicking ass dude :1poke:
great numbers!
Untuned?... you mean there's more?!
:bowdown:
Congrats, Krister.
Discussion Starter · #18 ·
:bowdown:
Congrats, Krister.
That things timeing is at 8 degrees, and personally that turbo needs a standalone because of the fast spool, and high power out put.
Just to let you guys all know, the numbers are 450whp / 500ft-lbs @ 21psi. The 533hp is a calculated crank number figure. I am still sure I will break 500whp with some tuning and couple of pounds of more boost. Im just afraid to put more boost, I'm not sure if the tranny and clutch will take all that torgue this turbo is producing :eek: :)
I'll also invest to some cams because the power peak is at 5200rpm and it starts to fall off fast after that. Here is a dynosheet:
Hp is in RWKW (1kw = 1.34hp), Torque is in rear wheel newton meters (Nm) (100Nm = 73.76 ft-lbs)
Resulting in 450whp / 500ft-lbs
Here's a pic of the car for those who havent seen it: :)
Thanks for the support guys :)
blackout_89t said:
Now that I like.
Congrats.
HKS VPC + S-AFC
Stock ECU ftw :)
1 - 20 of 33 Posts
