1 - 18 of 18 Posts
Moderator, l337 M0d3r4t0r
This is going to be a list of places that you can purchase Toyota wiring harness parts.
Here are the best sources I like to use.
http://cycleterminal.com/
Great on pricing fast shipping, lots of other non-Toyota connectors which help for other things like if you are using Greddy gauges and what not, you can find the connectors here for them. (in my case the solenoid and pressure sensor connectors for the profec e01) Harder to navigate simply because they do have a list of what parts for the supra specifically the parts are used for. Like their tools provide great crimps for me
https://www.corsa-technic.com/
Another good source for all sorts of connectors. Again not supra specific but have a verity of everything.
http://www.yotaconnectors.com
Great place supra specific, not a huge selection yet.
http://www.wiringspecialties.com/
Lots of hard to find harness connectors, but very pricey
http://www.driftmotion.com/
Good list of commonly used connectors, but not a full list. Mostly JZ specifc
http://www.easternbeaver.com/Main/El...-MT/sm-mt.html
Great selection and lots of crimping tools
http://www.dealerquickparts.net/Clist.aspx
Use this site to find the connector part number and who makes it, very handy. Many connectors have the part number on the back but not the full Toyota part number. This will help you find that.
http://kinkong-connector.com/
Just found the holy grail of connectors from china, where all these guys get their connectors
Also see this thread.
http://www.supraforums.com/forum/showthread.php?723506-Wiring-Harness-Repair-and-Re-Wire-(connectors-terminals-etc-)
Supra Tech
A couple other good ones.
https://www.bmotorsports.com/shop/index.php/cPath/109?osCsid=oe1nbp08os415h0uu5g90uc1g1
http://www.easternbeaver.com/Main/main.html
https://www.waytekwire.com/products?clear=true
And as far as connectors I just built my harness a year-ish ago, and I was able to source alot of the connectors straight through Toyota. Well, Curt was able to anyways, he had back door connections to the underground gangs in Japan that were hording all the connectors. He found them, i didn't care how he did, but he did.
Toyota Wiring
https://drive.google.com/open?id=0B0hS23BemdNSYjFLTklaSGNDTmM
My documentation from my 91 Harness
https://drive.google.com/open?id=14L4C9LJKQHw34Iw2gJNHb-HnvlIKAdNHkepgys2jp4U
So I found the grommet number of the stock wire harness, but never have been able to find a replacement with the part number. Anyone actually ever found a real replacement part?
Update on the firewall grommet, I went to the pick and pull, found the Camery from 90's has the same sized firewall grommet, except it has a longer neck. Works perfectly! Scooped out a few just for good cause.
i have been purchasing everything i can connector/pin/body wise but everything already posted is everything i have been able to find in the last year or 2. ill dig after work and see if i can find anything not already here... let me see what i can dig up
Discussion Starter #8
Anyone know who makes the TPS connector for the 7m? It's odd since it has a metal push fitting. Once I know the brand we can figure out the series. Drift motion has some serious markup on some of the items. Like the Pins are 50 cents for the wire seals where as corsa or cycle terminal are like 10 cents. Makes a difference if you are wiring the whole harness again.
The TPS connector is this one http://www.yotaconnectors.com/product-p/yc-4p-7mtps.htm . I bought the TPS one on sale for $2 but I had to cut out a small notch in it for it to work but that one also works as well if you go that route. I also ordered a bunch of small pins and their prices are much better on that site as well.
Anyone know where to get a cold start injector and cold start injector time switch clip replacement for a 87?
Discussion Starter #12
It's nice but that connector is very expensive and doesn't have enough pins for me since I'm 2jz. If i'm going standalone sure.
Discussion Starter #13 (Edited)
Has anyone been able to find the gray ecu connector terminals? The link referenced above mentioned yellow ecu terminals.
Sent from my LM-V350 using Tapatalk
Hi Guys
I Have Read This Post Very Interesting And Very Useful Article Thanks For share
Ballenger Motorsports - High Performance Electronics
The place for all your motorcycle electric needs.
Waytek | 12V Electrical Components Distributor
Toyota Wiring
Wire Harness Repair.pdf
1991 7m Harness.xlsx
Informative content
this couldn't have come at a better time. just need a few connectors (what i think) but will probably be making my own harness to go with the ecumaster black. thanks for taking the time huge asset
1 - 18 of 18 Posts
