Hi everybody,
I'm trying to connect my fans to my aem v1 but can't get them to work. No matter what settings I choose or how I connect the relay, it doesn't work.
Can anybody help me?
do a search but i can't find anything un the forum.
Thanks in advance
Mind if I do a J?
How do you have the relay wired and what trigger are you using on the AEM?
Hooked to LS10. I wired the relay like this:
-30 to battery
-87 to fan+
-86 to AEM
-85 o +12v
Is this ok? Fan are ok,If i bridge pin 87 to pin 30 works perfectl.
89 Turbo - 2JZGE-T VVti (build/swap in progress)
-30 to battery
-87 to fan+
-86 to AEM
-85 o +12v
85 should be ground I think
Solved,problem was settings in aem. This is how I hooked everything:
-30 to battery (40A fused ALLWAYS)
-87 to fan+
-86 to AEM
-85 to +12v switched
outputs LS3 and LS4.
IMPORTANT: PIN 85 in relay must be hooked to a 12V Switched source, if you use a 12v Constant source fans will go on when you turn off the car.
