1 - 4 of 4 Posts
ok i have an 86.5 na ok i drive home smell coolant but the car is not overheating pop the hood steam coming out from under the intake mani cant see from where exactly and fluid is dripping down from somewhere cant see where..... later samething but car overheated and then died which i think is due to a ded battery please help what ahppened
function > form
Didn't you just have a post about the same subject? You should subscribe to your thread so you don't create more. Did you check the coolant lines under the intake manifold like someone mentioned in your old thread?
i had a similar problem...turned out to the the line that went from the ISC to the TB...the hole in it was the size of a pin hole....my buddy managed to pick it out.
same symptoms though...smell of coolant w/o overheating and steam coming from under the intake.
thanks hellraiser thats what i was looking for some one with the same problem or who has experienced it before.
1 - 4 of 4 Posts
