ok... the bad..
lose coolant after driving.. the radiator always has coolant present in it when opening the cap after parking. not necesarilly full to the brim with coolant, but enough.... and the reservoir eventually will settle way way down to almost nothing left even after filling.
i have no coolant leaks.
i have no problem with pressure, just pressure tested it up to 23 psi.
i will have heat until the system goes through the coolant and then i lose heat and the coolant level in the reservoir becomes low.
can't smell any coolant with the heater on and blower on, no coolant smell inside the car.
have never overheated.
engine never feels excessively hot even after hard runs.
never had a problem with oil or water looking the wrong color.
i haven't noticed an excessive amount of white smoke at any time.. startup or boost. every once in a while i will see a little bit, but nothing to make me lose that much coolant that fast.
what could the issue be?
