wut
What ratios of coolant and distilled H2O are you guys using in your system? What about water wetter, are you just including a bottle of it?
For Michigan in summer use 60% water, 40% coolant and one bottle of Water Wetter (ex Supercool). For the winter or cold weather in general, 50-50, no additives.
wut
So for higher engine temps, like in the summer, it is better to use a higher ratio of water than coolant?
Water dissipates heat better, coolant is there to lubricate the system and protect it from freezing (thus also called Antifreeze). Which one would you like more of in your system when temps are just under 90F?
wut
Heh, heh thanks for the info:)
