1 - 4 of 4 Posts
I was just reading through an old thread and found information saying you may have plugs/repair kits for the coolant sensor to ecu plug. The information in the old thread:
90980-11062 CONNECTOR 2 PIN LIST 8.22 COST 6.16
82998-12620 TERMINAL,& WIRE LIST 24.57 COST 18.43 EA X 2
Not sure those are the part numbers I am looking for or not. I have an 87 MK3 with the 7mGTE motor with yellow plugs on the ECU.
Any help would be appreciated.
I would need 1 of the 90980-11062 and 2 of the 82998-12620 for a grand total of $51.27 correct? I am in the process of trying to test mine to see if it really is bad, but want to be prepared just in case it is.
Do you happen to carry the stock 440cc injectors for the 7mgte? Every where local to me that carries them want $100 a piece making it $600+ tax.. I can upgrade to 550cc injectors for less than that..
Anime Dork
23209-42010 injector list 201.90 cost 151.42 x6
90980-11062 housing, list 8.76 cost 6.57
82998-12620 terminal, list 29.80 cost 22.35 x2
1 - 4 of 4 Posts
