Andi,
Great write-up. I wouldn't ditch the stock oil cooler. It gets coolant after it goes through the radiator, so the coolant is going to be cooler than the oil. They don't put much heat into the cooling system either. It has the side benefit of heating the oil up faster on cooler days, and keeps the Greddy from overcooling under those conditions, which is a concern with air/oil coolers.
I used to run a small flexible spoiler under my Talon to get more air into the radiator behind the FMIC like you and Jeff are doing. It seemed to help. The only problem with the way you're doing it is that might be a low pressure area where you have your opening since it sits behind the little stock spoiler. The little flaps you left hanging should help though.
I'm probably just going back to the SMIC myself. It's hard for me to justify the cost of a FMIC and Fluidyne for the improvements I saw on my car.
