I've search and searched and i'm not sure what the exact answers are with respect to cooling mods needed to road race with a FMIC. The assumption is that a 3-row or equivalent FMIC will be used during a road race at warm temperatures (85-100 degrees). With your assistance, the hope of this thread is to be the authority on the topic. The goal is to educate those considering road racing the SupraTT. The scope of the thread includes all cooling modifications (brake, power steering, engine, etc.) and will be divided into two categories BPU (stock twin turbos) and APU (single turbo). For further clarification, BPU will be defined as stock twins and bolt on peformance upgrades (boost, pipes, intake), and APU will mean any upgraded single turbo (realistically seen on a road course) and any other supporting mods. Obviously there will be a bit of overlap, but it will help those at various stages. Please comment and add to thread as you please.
QUESTION: WHAT COOLING MODS ARE NEED FOR A BPU AND APU SUPRAS WITH FMIC? [PLEASE ADD OR FILL IN MISSING ITEMS, COST, AND LEVEL OF NECESSITY. THANKS]
BPU SUPRA
Cooling Item / Cost Range / Necessity
1) Radiator/~$500-?/Helpful, needed on hot days
2) Oil Cooler/ ~$200-$880/ Needed/Absolutely Necessary
3) Transmission Cooler / ??? / Not Needed
4) Power Steering Cooler/ $20-$120/ Absolutely Necessary
5) Radiater Scoop / ??? / Helpful
6) Vented Hood / $400-$1500/ Helpful
7) Brake Ducting / $40/ Needed
8)Radiator Cap / ~$37/ Not Needed/Helpful
9) Thermostat / ???/ Recommended/Needed
10) Oil Cooler Ducts/ ??? / Recommended/Needed
11) Power Steering Ducts/ ??? / Recommended/Needed
12) Fan between Radiator and FMIC/ $85 / Not Needed
13) Upgraded Fans behind Radiator/ $400 / Not Needed
14) Upper Radiator Plate/ $80-$150 / Not Needed - Hood sufficiently traps air
15) Oil Cooler Ducting/ ??? / Helpful?
16) PWR Steering Cooler Ducting / ??? / Helpful?
17) Fan for Oil Cooler / $69/ Helpful/Needed/Absolutely Necessary?
18) Fan for PWR Steerting Cooler/ $69/ Helpful/Needed/Absolutely Necessary?
19) 160 Degree Thermostate/ $83/ Helpful/Needed/Absolutely Necessary?
Current Total NEEDED/ABSOLUTELY NEEDED COSTS: [INCOMPLETE]
_________________________________________________________________________
APU SUPRA
1) Radiator/ ~$500-?/ Helpful, needed on hot days
3) Transmission Cooler / ???/ Not Needed
5) Radiater Scoop/ ???/ Helpful
6) Vented Hood/ $400-$1500/ Helpful
7) Brake Ducting/ $40/ Needed
8)Radiator Cap/ ~$37/ Not Needed/Helpful
9) Thermostat / $75/ Recommended/Needed
10) Oil Cooler Ducts / ???/ Recommended/Needed
11) Power Steering Ducts/ ???/ Recommended
12) Fan between Radiator and FMIC/ $85/ Not Needed
13) Upgraded Fans behind Radiator/ $400/ Not Needed
A sticky on coolers (oil, pwr steering, etc.) can be found here: http://supraforums.com/forum/showthread.php?t=165165
BPU SUPRA
APU SUPRA
