1 - 3 of 3 Posts
well i took my cas out 3 days ago because the car was missing and i decided to reinstall the cas into the motor and when i did it would not start and i followed the book to the t but no starting so i was wondering if anyone could explain it to my cause the book makes no sence
Destroyer of Turbos
make sure the #1 cycl is at tdc. from there line up the cps so that the bigger lobe is toward the back of the motor but is lined up with the start of the 2 pickups. gently insert into the hole and work back and forth a little if needed. should work well!
Addicted to oil
1 - 3 of 3 Posts
