1 - 20 of 28 Posts
i know this has been discussed alot but do u need alot of parts to go from a auto TT to 6spd TT isnt it jsut the trans u need? also a final price would be nice.
You need way more than just the trans. It's been a while since I swapped, but I remember having to get a trans, diff, clutch, and ton of smaller part. Also the driveshaft has to be swapped or modified IIRC. Figure $2-5K for used parts (depending on condition), and a whole lot for labor if you don't plan on doing it yourself. It would be cheaper to sell your car and buy a 6spd.
Do a search, as I remember some old threads that had detailed lists of all the parts need for the swap.
Very Senior Member
KrAzY K said:
Some guy is gonna do it for me $6000 for all the parts (used) and a rebuilt tranny and labor.
See if "some guy" is doing everything on the list Mystik has. I doubt it.
But - maybe you are lucky!
Discussion Starter · #10 ·
Just finished my swap right before tx2k5. I ended up spending around 7,000 on parts . I could have spent less$ but i figured this would be a good time for an better clutch, new flywheel, trd lsd, b&m short shifter, trd tach and other misc stuff.I thought about selling my car but with only 30xxxxmi it would be hard to replace, in the end it all worked out and i couldnt be happier.
For anyone that is curious as to what is needed, parts and cost, look in the Elmhurst Toyota section, Curt has a very comprehensive list.
Newbie
16620-46070 tensioner list 196.17 cost 145.07
16621-46010 bracket list 40.41 cost 29.89
16622-46010 arm list 19.26 cost 14.24
16602-46010 shock absorber list 62.56 cost 46.26
91511-g0845 bolt list .91 cost .68 x 2
90901-16001 stud list 2.09 cost 1.54
90179-08171 nut list .89 cost .65 x 2
90116-08348 bolt list .83 cost .62 x 2
90080-17242 nut list 1.37 cost 1.01 x 2
parts total : 242.92
Clutch parts:
90363-12002-77 pilot bearing list 8.76 cost 6.48
96152-00500 snap ring list 2.66 cost 1.97
90903-63001 t/o bearing list 65.50 cost 48.44
90560-50001 snap ring
90560-79001 spacer list 2.31 cost 1.71
90206-12006 wave washer list 1.57 cost 1.17
90520-75001 snap ring list 2.97 cost 2.20
31264-14060 spring list 2.97 cost 2.20
31231-14050 hub list 33.38 cost 24.69
31204-14060 fork list 65.16 cost 48.18
31234-14020 spring list 1.97 cost 1.46
31236-14030 support list 31.27 cost 23.12
90119-08079 clutch cover bolts list .46 cost .33 ea x 6
90119-10054 bolt list .86 cost .64 x 2
90910-02115 flywheel bolts list 9.72 cost 7.18 ea 8
13450-0W011 flywheel list 611.96 cost 452.53
Use your own supplied clutch cover and disc. See up-grade list at the end of this post for the TRD single disc or TRD twin disc kits.
parts total : 674.85
Transmission:
33030-0w212 v160 assy new list 5478.75 cost 4774.12
31123-14020 inspection cover list 29.84 cost 22.07
31121-14030 inspection cover list 36.18 cost 26.75
90080-11228 bolt list .69 cost .50 x 4
08885-01306 v160 oil qt list 47.62 cost 35.21 x 2
Transmission comes dry shipped, no fluid.
parts total : 4895.36
Clutch Hydraulics:
http://www.mkiv.com/techarticles/au...side/index.html
31470-14060 slave cylinder list 64.61 cost 47.77
90080-10055 bolt list .89 cost .65 x 2
31410-14310 master cylinder list 99.39 cost 73.49
90179-08237 nut list .91 cost .68 x 2
31481-14260 tube list 20.52 cost 15.24
96816-50335 hose list 24.86 cost 18.47
31484-24010 bracket list 6.69 cost 4.97
31482-14060 tube list 10.89 cost 8.06
90119-06406 bolt list .69 cost .50
96991-10080 clip list 1.20 cost .89 x 2
90119-06733 bolt list .54 cost .41
90080-11231 bolt list .51 cost .38
90461-08702 clamp
79191-00502 Castrol GTX brake fluid pt. list 3.75 cost 2.50
Braded TRD clutch hose available, see up-grade list at end of post.
parts total : 176.23
Transmission mounting/driveshaft
12371-46110 trans mount list 70.56 cost 52.18
90119-08770 bolt list .89 cost .65 x 4
90179-08159 nut list .89 cost .65 x 4
90201-11013 washer list .52 cost .38 x 4
90179-11017 nut list 1.51 cost 1.12 x 4
37100-14810 driveshaft list 675.26 cost 499.33
90119-10217 bolt list 1.51 cost 1.12 x 2
90105-12265 bolt list 7.63 cost 5.65 x 3
90560-12059 spacer list 4.12 cost 3.04 x 3
90179-12128 nut list .91 cost .68 x 3
TRD trans mount available, see up grade list at end of post.
parts total: 593.06
Shifter assembly:
http://www.mkiv.com/techarticles/au...6spd/index.html
33504-14130 shift knob list 103.63 cost 76.63
33511-14031 control shaft list 25.15 cost 18.60
33513-22030 yoke list 7.63 cost 5.65
33530-14442 93.5-95 short throw shifter list 126.44 cost 93.49
90301-11015 o ring list 2.92 cost 2.15 x 4
33531-14010 boot list 39.44 cost 29.16
90387-08134 collar list 1.91 cost 1.41 x 2
33555-14110 boot list 31.55 cost 23.33
33555-14100 boot list 9.83 cost 7.27
33556-14050 seat list 1.54 cost 1.14
33057-14010 bracket list 44.33 cost 32.78
33570-14070 shifter tri-pod list 96.77 cost 71.56
93381-16016 bolt list .85 cost .55 x 4
90179-08095 nut list 1.14 cost .85 x 2
90105-08200 bolt list .89 cost .65 x 2
91651-60835 bolt list .26 cost .20 x 4
90105-08076 bolt list .74 cost .55
90179-08233 nut list .91 cost .68
90250-06026 pin list 1.06 cost .79
90467-21010 clip list 2.61 cost 1.93
You can use the B & M shifter in place of the stock one.
parts total : 380.98
Console parts:
http://www.mkiv.com/techarticles/au...nnel/index.html
58261-14010 upper trans tunnel list 78.54 cost 58.08
58994-14010 console bracket list 6.74 cost 5.01
91651-60614 bolt list .94 cost .71 x 2
58804-14060 shift bezel w/boot 93.5-96 list 140.44 cost 103.85
58804-14100 shift bezel w/boot 97-98 list 140.44 cost 103.85
parts total : 168.36
Brake pedal:
47101-14230 brake pedal list 49.67 cost 36.88
31321-14020 brake pedal pad list 3.23 cost 2.39
You can re-use the misc parts on the brake pedal bracket assy.
parts total: 39.27
Electronics:
83242-1u310 6spd tach list 118.75 cost 88.19
89661-14521-84 ecu 6spd obd1 93.5-96 list 1111.50 cost 913.53
{includes 100.00 core charge]
Call for obd2 ecu pricing.
If Dusty @ MVP has them available you can use the TRD 10K tach.
http://www.supraforums.com/forum/sh...threadid=181819
parts total : 1001.72
Clutch pedal:
31311-14120 clutch pedal list 42.18 cost 31.32
90541-06036 cushion list .83 cost .62 x 2
90949-03011 spring list 1.93 cost 1.43
90386-13015 bushing list 1.37 cost 1.01 x 3
90949-03013 spring list 11.40 cost 8.47
31321-14020 pedal pad list 3.23 cost 2.39
90101-10015 bolt list 1.00 cost .74
90387-10003 collar list 4.54 cost 3.36
31353-14010 holder list 3.34 cost 2.47
90240-08006 pin list 1.71 cost 1.27
90386-08010 bushing list 5.37 cost 4.00
55107-14140 support assy list 69.76 cost 51.80
91655-60630 bolt list .60 cost .47
90119-08a22 bolt list .71 cost .53
96160-00600 e ring list .63 cost .47
94512-01000 washer list .63 cost .47
94110-51000 nut list .60 cost .47
90386-05017 bushing list 1.91 cost 1.41
90206-08001 washer list .83 cost .62
90468-16142 clip list .72 cost .53
88280-14030 switch list 16.60 cost 12.32
84520-24010 switch list 38.64 cost 28.68
94120-41000 nut list .60 cost .47
parts total : 157.96
Rear differential:
http://www.mkiv.com/techarticles/au...tial/index.html
41651-14010 mount list 81.14 cost 60.00
41110-14780 6spd lsd diff assy list 2563.80 cost 1895.85
79191-00672 75w90 Castrol gear oil list 13.95 cost 10.15 x 2
42340-14140 lh drive axle list 393.49 cost 290.97
Diff comes dry, need to fill.
Up-grade to TRD LSD UNIT see list at end of post.
parts total : 2267.12
GRAND TOTAL:[ for those of you who don't know how to use a pocket computer or are to lazy]
242.92
674.85
4895.36
176.23
593.06
380.98
168.36
39.27
1001.72
157.96
2267.12
_______
10,597.83 SHIPPING NOT INCLUDED
That's rather inflated, most people doing this swap A.) aren't going to be buying new parts for the tranny/diff, B.) are probably putting in a JDM motor which will include an ECU OR they'll be going standalone. If you look hard enough I'm sure you can find someone who's gone 6 speed to auto and grab the majority of the "clutch parts:" for a reasonable price. I'm not sure the tach is necessary(could be wrong with this).
Buying clutch parts from Toyota is a bit silly too, they absolutely killed me on parts for my MK3 when I needed to buy stuff through them. Definitely worthwhile to take the time and try to find someone parting a few things out or looking into anything you can find aftermarket.
On 2 wheels
Why not just sell your car, buy a 6 speed, and then use that money you were going to dump into a swap for a single kit?
Exclusive 1000+ Post Club
Clutch parts:
Transmission:
Clutch Hydraulics:
90461-08702 clamp
parts total: 593.06
Shifter assembly:
Console parts:
Brake pedal:
parts total: 39.27
Electronics:
Clutch pedal:
Rear differential:
242.92
674.85
4895.36
176.23
593.06
380.98
168.36
39.27
1001.72
157.96
2267.12
_______
Exactly; search!
http://www.supraforums.com/forum/showthread.php?s=&threadid=211926
You are an idiot. First, most people are going from auto to stock 6 spd from my experience. Secondly, I have not seen anyone that I can recall doing an auto to JDM 6 spd? WTF. It's the same fucking thing so how's the cost going to be different? Most people do have to buy new parts. Where are you going to find good used synchros? I guess people are just ditching good used parts for fun now. It's not easy to find good used 6 spd parts. It's very difficult and VERY time consuming. It is worth the money to buy new parts for 1) time invested and 2) heacaches of buying crap and getting punked. I don't know if you noticed, but aftermarket parts are most expensive, and more importantly, not warrentied by Toyota.
Jaxx has the right idea.
Edit: the link is in the Toyota/Scion section. Contact Curt Aigner.
Joe
First off Thanks for the words of encouragement! :D Second, auto to stock 6 speed you can still pick up a v160 with a bad synchro for around $1k-$1.5k and rebuild it for cheaper than the cost of a brand new one. The cost of JDM Auto to 6 speed(or even stock auto to 6 speed) will be different because you initially don't need the 6 speed ECU if you can live with the timing pull. Used synchros? wtf I was talking differential/transmission/etc all the big parts which you can get when people upgrade.
Warrantied parts... You're kidding right? You put a warrantied part in a modified car and toyota's going to laugh at you when you bring it in. Not to mention they laugh at you anyway for parts that could take abuse from "the way you drive." They tried to blame 3 clutch failures on me when it was their fault for putting in one with the wrong number of dampeners and this is on a stock car. I had to do a load of research and I finally got it out of my one of my father's friends who owns a dealership out in the boonies that toyota was putting the wrong clutches in this particular car.
Supra TT Senior
A simple search would have done the trick lad...I believe Curt has that sticked since people like to ask so much...
1 - 20 of 28 Posts
