1 - 20 of 24 Posts
Curt,
Current part #s/prices on the following for a '93 mk4na, please...
-- oil filter
-- oil plug gasket
-- plastic snap-in cap that covers the front bolts when the targa is off
-- rear right and left upper control arms
-- front lip (just the plastic)
-- front plastic undertrays
-- longshot... plastic plug-cap fitting on the end of the tonneau cover's rod
Thanks!
90915-yzzd3 Filter, Oil List 5.41 Cost 4.03
90430-12031 Gasket Plug List 1.00 Cost .75
63296-14020 Cap, List 4.49 Cost 3.38
48770-19025 Arm Assy, List 315.58 Cost 237.15
48790-19025 Arm Assy, List 315.58 Cost 237.15
76851-14060 Spoiler List 482.37 Cost 362.50
51442-14040 Cover, Under List 144.38 Cost 108.50
51441-14140 Cover, Under List 166.45 Cost 125.09
62910-14060-c0 Cover Hatch List 103.97 Cost 78.14 [the Rubber Caps Are Not Sold Seperately]
Thank you Curt. I will be emailing you an order shortly for some the items above.
A couple of questions, please...
1) Do all of the 5 bulbs in the climate control cluster need to be replaced together? It looks like only my temp control knob isn't lit well and the fan speed control knob is dimmer than others.
2) I replaced the bulb beneath the autotrans gear indicator panel near the emergency brake handle, but I noticed that the indicator (the little line that moves with the selector lever and lines up with the selected gear) is unlit. Is there another bulb in there? If so, part # and price, please?
Thanks again.
1] Yes replace all of them. if one is burnt out the rest will follow.
2] 90981-11036 BULB LIST 2.14 COST 1.61
Thanks Curt.
So there is a bulb that lights up the indicator mark... I don't see how to get at it though. I changed the bulb that lights the letters without too much hassle, but do I need to pull the bezel that surrounds the shifter to get at this new one? I can get it released from it's 4 snap clips, but no way to get it off the shift lever. I've got the FSM, but the pic isn't very detailed. Can you advise?
Thanks again. :)
Thanks.
Is there a way to get the PRNDL bezel off without pulling the selector lever? I stumped...
Remove the console box to get at the gear selector sides to replace the bulb.
You have to remove the shift knob get get the PRNDL bezel off.
Discussion Starter #9
Thought so... just haven't figured how to do that yet. Was hoping for an easier way.
Thanks.
Discussion Starter #11 (Edited)
Is there a page number in the FSM that details removing the auto shifter knob?
Or any other reference I could look at?
Here is what I'd like to order:
x5 -- 90915-yzzd3 Filter, Oil
x5 -- 90430-12031 Gasket, Plug
x2 -- 63296-14020 Cap
x5 -- 84999-70009 Bulb Assy
x2 -- 90981-11036 Bulb
I've sent this by email along with shipping address and payment info.
Thanks! :)
Discussion Starter #13
got the scans... thx! :)
looks kinda complicated... :(
Discussion Starter #15
Package arrived yesterday.
Thanks again! :biggrin:
Discussion Starter #17
I even managed to get the 5 bulbs behind the HVAC controls changed without breaking anything.
I'm a little disappointed though... I'd hoped that the TEMP dial would be brighter, especially the indicator mark on the knob. Even with the dash brightness at MAX, it's kinda dim. But it's better than before.
Any way to brighten things up? Pull the greenish sleeve off the bulb, maybe?
Thanks!
Discussion Starter #19
Buttons look good to me.
Can the indicator dials of the fan speed and temp controls be changed? If so, part #'s and $, please. Also part # and $ on the temp control knob.
Thx! :)
1 - 20 of 24 Posts
