1jz-gte motivation
First, I am going with an aftermarket radiator and fan assembly. What size fan/fans do I need to keep the fluid in the koyo radiator at a decent operating temp. I am sure it will need to be a puller style, but what cfm should these fans move? what set-up do you guys have and what will fit? Also, anyone know where to get an oil filter relocation kit for the 1jz at a good price? Thanks.
1jz-gte motivation
Discussion Starter #2
Also, the 1jz auto flywheel is the same as manual correct?
Engine Geek
auto and manual flywheels are different. you should be able to use a oil filter relocation kit for a 2jz... makes it easier to find. not sure what cfm you need for the fans though
1jz-gte motivation
I was thinking 2500.
1jz-gte motivation
anyone...come on!!
