1 - 11 of 11 Posts
" its not a Tuuurbo"
would cracks in the head gasket in-between the cylinders cause oil burning? prior to the disassembly. when the car was running when ever i get on it it would puff a good amount of blue smoke (oil). would the cracks on the head gasket cause this?
Discussion Starter #2
also since im now in the area to shop for a new MHG. what is the popular way to go with? which brand and size?
wouldn't cause oil burning as far as I know...but you're gonna be down on power regardless...
well everything is apart now, when i put it all together ill do the compression test.
any ideas on a MHG?
I'm using cometic... as are several high HP guys...
lol, I'll be lucky if I'm near 300HP....and the milage it's getting it would be nice to be that high...
16MPG SUX
I used cometic because it's more forgiving than the HKS (didn't have any good info on lapping, then RIGHT after the engine was back in a running that large thread on lapping popped up)
that and HKS isn't cheap...
maybe when I have a built engine I'll run one, but cometic isn't bad...
1 - 11 of 11 Posts
