1 - 3 of 3 Posts
Hi guys 89 supra 7MGTE. I have an intermittent crank no start, when it doesn't start, i realize the injectors don't spray ( used a noid light ) but then when it decides to work, then so do the noid light hence the intermittent crank no start. I have spark, I have fuel.. So I'm gonna have to say it's my CPS ( Camshaft position sensor) going bad ? 189k on the motor
· Frozen Lake Driver
Check the wires on your CPS and also check all your grounds. If your injectors aren't firing it leads me to believe a dead ground on the Resistor or somewhere on the ECU's wiring.
1 - 3 of 3 Posts
