1 - 3 of 3 Posts
Quick question. Does anyone know what size bolts I could use with a puller to remove a BL crank pulley?
9's Club
Either use puller that has three arms and grabs the pulley by the outer lip, or I know that stock pulley uses M8 bolt thread.
I believe my Boost logic crank pulley used 1/4" bolts. Do not use the puller that has three arms as the pulley is pressed in there quite tight and it may damage the pulley if you use that one.
1 - 3 of 3 Posts
