Doc, It'll still be a while before I really get into doing it all (need my doner engine first...then assemble everthing for the rebuild). At the rate I've been able to set aside cash for the Supra at the moment, it could be this time next year
Dry sump...would be nice, but for my purposes will likely be overkill. The accusump should suffice.
knife edging is a thought, though I've heard both good and bad from it. As I'm planning to go with a lightened flywheel, and may need to consider a drive shaft to replace my currently busted centre bearing, I may end up removing more mass than I want should I go for it.
MA71, The kick-out probably has a more correct name...in essence, yes, it is a box or similar welded low in the sump area to increase oil volume around the sump, and set off to one side so as to keep oil from washing out as quickly. I haven't ever had a need to take the pan off before, so this tray may be me looking at something unneeded as well, but it does give one more oil control option should it be discovered that it could help.
Bob
