If you catch your engine at the beginning of crankwalk symptoms is it possible to just replace the main bearings and check thrust clearance? Obviously checking the crank for any damage while the caps are out. I've read that most guys have just scrapped there engines once they've crank walked but im wondering how severe it has to be before doing so. My rps drop about 400 rpm when my clutch is engaged and i can see the crank pully move out about a mm or two when the clutch is engaged. I dont have any front seal problems, and am wondering if any movement over factory clearance would damage any other internals or if i can just put new bearings in and tighten everyting back to spec?
