1 - 7 of 7 Posts
i just finished completely rebuilding my 7m-gte in my truck and it would seem that when i hit the clutch the crank pully rubs the timing cover. on my old engine i had about 1/8" of clearance between the 2 on this engine theres none..... same with the other 2 7m trucks i have sitting here. is there supposed to be some sort of spacer?? or is there a difference on different years of cranks
JZS161 Aristo TT
Thrust washers :ugh2:
http://www.cygnusx1.net/supra/library/TSRM/em/EM_91.html
yep they are in there and the crank only moves a few thou when the clutch is depressed.
i didnt' check.....
but regardless the crank pulley sits against the timing cover
1 - 7 of 7 Posts
