Well I'm looking into putting a 7m-GTE in a BMW 328i. It just seems like a great thing to do for someone who wants a cheap, reliable, 350rwhp...but I got some questions and my Supra knowledge has thinned a bit so forgive the noobish ones.
First, will the CT26 handle 350+rwhp, or do I need to look at something else?
What all needs to to be done to support 350+? I assume lafm/550's (along with an S-AFC and a big walbro), good intake, intercooler, exhaust, and 18~20psi?
Obscure, but does anyone know the distance between the front of the bell housing to the shifter on the R154?
I'm also curious what all systems are run by the ECU? Does the dash operate fully off the ECU or is it just the tach and idiot lights? Does it run the fuel pump?
Lastly, what were the available ranges for the rear ends on the MKIII? I know they were pretty short...4:10 comes to the mind but can't remember if they were that short.
My plan here is to stab a 7m and a R154 into the car and fuse the MKIII drive shaft to the M52's stock drive shaft. A lot of the BMW dash runs independent of the ECU...only tach and lights, but the BMW tach operates like an aftermarket one (power, signal, ground...not data), so all I'll need to source from the MKIII ECU is a tach signal and my idiot light signals and splice them into the stock harness.
It's hard to explain and seems real simple in my mind, but I know it probably won't be. Any help with the questions would be greatly appreciated! Thanks!
