1 - 13 of 13 Posts
first can you help me with this
http://www.supraforums.com/forum/showthread.php?p=4241991#post4241991
2nd
how much for these items
-battery tray
-stock pressure tank
-pressure tank bracket
-oil pressure switch
-union
-oil level sensor
-air cleaner duct
-TRD Radiator Cap
-right and left inside front fender splash guards
-inside fender linings(left & right)
-all the tabs bolts that are needed to hold the splash guard and lining in place
-the front spoiler and items that hold it in place under the front bumper
ps: didnt forget about sending you them items.
Discussion Starter · #2 ·
what are these items exactly and price
TRD Sports Coolant=? coolant mixed with distilled water ?
TRD Engine Oil (Super Sports PRO)=?
TRD Engine Oil (Super Racing PRO)=TRD Engine Oil (Super Racing PRO) 5W-40 (100% Synthetic) i know what this is :)
74431-14070 TRAY, LIST 73.08 COST 54.03
25709-46010 TANK /BRACKET ASSY LIST 51.27 COST 39.54
83530-AA011 SWITCH OIL LIST 23.21 COST 17.16
90402-16015 NUT, UNION LIST 7.95 COST 5.88
17751-46050 INLET, AF LIST 25.72 COST 19.78 NS
PT901-16401-03 RAD CAP TRD LIST 38.00 COST 33.21
53895-14010 Shield, Rf/frt List 70.39 Cost 52.05
53896-14010 Shield, Lf/frt List 73.39 Cost 54.27
53875-14190 Liner, Rf /rear List 62.10 Cost 45.93
53876-14190 Liner, Lf/rear List 62.10 Cost 45.93
76857-14030 RETAINER, RF UPR LIST 43.87 COST 33.64
76853-14020 RETAINER, RF LWR LIST 38.15 COST 29.22
76859-14010 RETAINER, CTR UPR LIST 82.77 COST 63.62
76861-14040 RETAINER, CTR LWR LIST 69.42 COST 53.30
76858-14030 RETAINER, LF UPR LIST 45.50 COST 33.64
76854-14020 RETAINER, LF LWR LIST 38.15 COST 29.22
76851-14060 SPOILER LIST 471.54 COST 348.68
90179-06143 NUT LIST 0.74 COST 0.55 X 11
HARDWARE FOR LINERS 35.00
Curt Aigner said:
Trd Usa Does Not Import These Items [ Fluids]
k thanks!
are these the front fender splash shields
like in this pic?
http://www.mkiv.com/manual/manualtt/front_stabilizer_bar_replacement/sb1.jpg
also how much for the 2 plastic or rubber tabs that hold each of the rear break ducts in place and also how much for the the slotted vents inside the rear break ducts area wheel wells?
Those are the front sections that attatch to the bumper cover.
41883-14010 grille list 24.78 cost 18.33 ea
90467-05042 CLIP black list 1.06 cost 0.79 ea x 4 [2 per side]
58901-14h00-c0 Box Console Assy List 98.32 Cost 72.71
just making my list!:D
Discussion Starter · #10 · (Edited)
1-can you get these items #s curt?
90401-19008 Union Bolt
90430-20016 Gasket
2-how much are black Outside door handles
3-oil drain bolt washers
4-also can you get me these items ?
hope this pic helps
#1a is the screw(i need one for each side)
#1b is the plastic rtab the screw goes into
i need one for each side (driver and passenger)
#2 i need 4 total
#3 i need the srews and the plastic tabs (total of 6 screws and 6 tabs)
#4a these are the bolts that hold the fender inplace down low i need 4 total for 2 for each side
#4b these are the spacers inbetween the bolt and the fender down low ( 2 for each side i need all 4 )
#5 i need all these tabs with the rubber hats to hold the side skirt or rocker panel (im not sure what is called )area in place forgot how many ( i need all for each side )
thanks!
Discussion Starter · #12 ·
i need brake vent in the circle for both the driver and passenger side .
1 - 13 of 13 Posts
