Need the gaskets / rings for both the oil and water pump.
Need the little clip / pin (just the hair-pin shaped clip is all) thing that holds the spring to the brake pedal arm.
need intake and exhaust cam seals
need the gasket that sits inside the oil pan for the pickup tube.
need the rubber ring that sits at the oil filter area and the block.
need ring / gasket that attaches to the water neck at the back side of the water pump.
All of this is for a 94 MKIV GTE.
You should have my info on file already.
Can you please let me know the total when shipped?
Thanks,
Should be under Charles Long Jr.
Thanks,
