Member
Curt i need some pricing and availability on
6 coil pack connectors
ECT sensor (engine control temps sensor) that mounts into the radiator (not the waterneck).
Primary O2 sensor.
Nick
Member
Thanks Curt.
I am having some issues with my car ideling really rich and really rough. I have been told it can be linked to the ECT sensor. I know there are 3 in the workshop manual. 1 in the waterneck, a 2nd in the radiator, and a 3rd on the ac/heater unit. I have read that if the ECT is failing the car will run very rich and idle very poorly. When i installed my aftermarket radiator, i didn't install the ECT on the radiator right away, left the plug in the radiator, eventually lost the sensor, and never installed it. I have a spare ECT for the waterneck that i will swap out and look for any change in the way the car runs. My question is, Do you know if NOT having the ECT sensor for the radiator will cause the ECU to do the above^ as well. Or does the ECU just get this kinda info from the ECT in the waterneck????
Nick
Member
Thanks so much. I don't have the auxillary fan, so i guess i don't need that...
I will let you know in a bit about the other parts^
