1 - 3 of 3 Posts
Supra Owner Since 1996
My favorite cutting tool is just your good old cut off wheel air powered or electric with a fiberglass/carbon cutting disk.
First scrape off the sound detoning padding, then you will see all the spot welds that hold that sub panel, drill thru all the spot welds, then hammer the sub panel down and off. Then get a neww one putt it where the old one was, and weld all the holes that you drilled and you are good to go.
1 - 3 of 3 Posts
