awhile ago i knew my valve seals were leaking...i did a leak down test and compression test to see if it was rings and it came out pretty good..not sure of exact numbers but was about 150-160 all around..so while i pulled the head and did the valve seals, i changed over to a cometic HG, and changed to anoter stock turbo since my blades were chipped and probably unblanced...i bought it used on the forums for about $75...everything looked good so i slapped it on for now...well i got the car back about 2 months ago and i check my oil every week or two. i noticed its been consuming oil again....about maybe a quart every 700-900 miles? well i changed the valve seals so it should be that, rings were good when i checked during leak down, so my guess is the turbo seals? i felt under the accordian pipe near the turbo there was oily residue, but havent checked the IC piping.. will do so when i do spark plugs and everytihng this weekend...it sucks becuase i jsut started to boost 12 psi
and i thought the turbo was good..i'm just hoping its not any rings but since i cehcked it last time it should be...anyone know where i can get the CT rebuilt to stock so i know the seals are good?
sorry for long post...it just sucks because i thought my car was gonna run perfectly...haha guess supras always has problems
