Well after a night of racing (and winning a few) my #2 Turbo wont come online anymore... these are the low mileage twins I just put on... there is no foul noise, the boost never goes above 11-12psi... and when #2 should be coming online my boost guage only shows #1 spooling down... there is no movement or odd characteristics when I hit the #2 rpm range... just #1 spooling down...
I checked the #2 turbo actuator hose or whatever you wanna call it that popped off a week or two ago and caused the same problem.. it was on securely... I looked as best as I could all over the engine bay and found nothing... however on the other side I THINK its for the EGR one of the hoses was off the little blue nub because the wire clamp was loose as hell... we put that back on, all it did was stop a hissing sound... no effect on #2... I checked all hoses around VSV... etc... I dunno what to check now... I cant find anything loose... so suggestions are very much appreciated... I wanna get this back to working tommorrow so I can have more fun... there is no death whine or sound at all.. #2 doesnt even seem to be awake.. so... Im clueless.
Im sure the suggestion of TTC will pop up... Id like to try everything else first, but I may go TTC tommorrow if its my last hope... im automatic bpu btw.. so lag might suck, but if it prevents killing #2 Its all worth it Id say... but ANYTHING I can check and hopefully may be a solution Id like to hear, thanks a ton.
