My dash lights are not coming on with the head lights. Is there a knob to adjust the intensity or a seperate fuse. Everything else works in the car electricly.
The dimmer? It's by the foglight and defroster switch on 89+. If that's not doing the trick it may need replacing. You can bypass it by jumping the white wire with the green stripe to the white wire with the black stripe where the harness plugs into the dimmer.
Dr. Jeff Lange
There is a knob under the dash on the left side to adjust intensity.
On cars with airbags it was moved higher up to a spot where the coin holder/fog/defog switches are.
Dr. Jeff Lange
Nah, it gets confusing trying to go by years for stuff like that, because the change was made with airbags, which happened for 1990 in the USA, 1992 for Canada, and the rest of the world never really got them.
Heh, I knew airbags were '90 here in the states, didn't realize they didn't make it to Canada until '92. So many little changes, at so many different times... ugh. I don't know how you keep it all in your head, but I'm glad you do. ;)
