Fly boys drive fast toys.
my lights in the little check engine light section dont work. i just got the supra so i am really new to it. i checked the fuses under the hood behind the bat. (94NA-T) everything was fine there, then i checked most of the fuses in the kick pannel fuse box. then i actually removed the upper pannel and checked all the light bulbs and they are fine. did i miss a fuse box? where should i look? and how to check if im even getting power to it?
Just re-solder the thing according to instructions in mkiv.com. It's a known frequent problem and it's easy to fix by yourself. Or have some of your friends fix it...
The same applies if your brake lights stop working. I had these both ;)
Newbie
Yeah, it's not hard at all. Once you open it all up, just go over the existing joints with a soldering iron. I didn't even have to add new solder.
