1 - 2 of 2 Posts
I noticed the manual says that one can datalog AFRs. Does this mean you can connect the appropriate wire from the wideband to an analog input and it will log the AFRs? Or do you need something extra for this to work? I'm using an AEM UEGO Wideband.
Yes, wire the output from the wideband controller to one of the analog inputs on the DET3, then set it up in the 'scales configuration' menu.
1 - 2 of 2 Posts
