1 - 2 of 2 Posts
Finally up and running!
What numbers are you modifying in the timing screen? If I put say... 13 in a field, will it give me 13* of timing advance on base, or 13* from whatever number it is pulling at that range?
The EMU can only add or remove timing, it does not know what the stock ecu is commanding, so what you see is a modification to the ignition timing commanded by the stock ECU.
1 - 2 of 2 Posts
