Map Sensor:
I should have researched this part more because this is the only screw up I made.
I tapped this boost sensor wire here and later read it out that it didnt privide enough voltage. Don't tap this, lol.
You need a map sensor to provide a signal source for the controller. As I said earlier, I first tapped a stock boost sensor thinking it would work. This caused to pump to spray about 1/8 tank of mix into my charge pipes while the car was off. As you can probably geuss I had to crank it for about 5 minutes before a sudden spout of meth sprayed out my BOV like a geyser, causing the whole shop to look at me with utter confusion.
