No Mercy
Hi everyone,
I'm gonna be changing my sparkplugs again soon, and I really don't want to buy OEM replacement breather hoses that go over the coil packs (the ones that you have to remove and replace to change the packs/plugs).
Does anyone know the internal diameter of these two hoses?
Thanks.
if the hose is still soft, you don't have to replace it. just remove it carefully. if you use an after market hose, i would suggest you get atleast a foot long so you can loop it. that's what i did untill the toyota dealer opened its doors the next day.
No Mercy
Unfortunately they're pretty brittle and cracked :(
I've gotta get replacements.
Anyone try a short length of aftermarket tubing?
SF.com Member #0000000023
What do you have against buying the OEM replacements?
mfh said:
Hi everyone,
Thanks.
I was able to use an aftermarket piece of tubing for the front tubes, but the rear tubes are too offset and too large to get a tube to fit there and seal. There's really no choice for the rear one, other than the Toyota piece.
