1 - 20 of 41 Posts
In front of you
Damn, that's a nice number you hit. Sadly, cannot say for sure if that is the best or not. Anyway, the stock cams are said to max out at around 700rwhp , so that's a good result ;)
Former Moderator
Wow! Very good horsepower Travis! You can see that you are really reaching the maximum efficiency of the cams at higher RPMs where your torque and HP drop very fast. Really nice curves other than that. What were the AF ratios? How do you like the turbo on the street?
-Olivier
Vivek also has a stock computer.
silvino said:
Well, stock computer is just as good as saying 'untuned' because the car would be dangerously lean or detonating from too much timing.
Huh? Are you kidding?
Big enough injectors and proper open loop tuning with a piggyback controller and it won't be lean. Enough octane and you wouldn't even see timing pulled on a stock ECU. The stock ECU is VERY good at avoiding detonation as long as you don't run insane boost for the octane. Its signal processing is lots better than an amplitutude based approach like the AEM.
Edit: Just took another look at the dyno graph and it says SAFC/VPC/G-Force. I've heard some G-Force ECUs have reduced timing but many (like mine) only have a raised rev limit and boost/speed cuts removed. It's a very smooth graph and certainly doesn't look like any detonation was occuring.
Mike
I am saying it COULD be this and that. Saying untuned doesn't mean for sure that you'd gain much or saying stock ecu doesn't mean for sure that you'd gain much from a stand alone (peak power wise). The reason I say this is that most of the time once people slap on a wideband or a way to measure timing, they realize that they're getting lean or knock and they didn't know it, that's all.
Mike
SupraForums Sponsor
Do you happen to have a dynosheet with a a/f curve on it? It would be very interesting to see what the fuel was doing. Congrats on the numbers.
Later
1 - 20 of 41 Posts
