Hi everyone,
Im trying to buy the fuel pump bracket for my 2jz-gte but the part is discuntinued . Anyone knows what are differences between the 2jz-ge bracket and the 2jz-gte bracket? Im in a big problem with this.
What is different between the GTE and GE versions that is stopping you installing the unit you have? I didnt realise there was a difference to be honest. Surely they cant be too different, apart from the size of the fuel pump diameter.
in the page 1 you can see the difference. The fuel return line in the GE is a long pipe but in the GTE model is a short pipe with a hose. Is this the only difference? And why this difference?
The GE pump hanger does not have a basket return port if I recall correctly so the sump can empty at high cornering in low level situations. With the return port (and a hose routed to inside the basket) the fuel in the basket remains full while the tank gets low.
bingo!
According to the query I have made to Toyota Europe, the GE hanger is used for the GTE model, a small modification must be made, you have to cut the fuel return pipe and put a hose to the fuel basket.
While on this subject, are there any fuel system stickies still left?
I am considering going back to an in-tank pump, and I was wondering what the transition from the factory lines to aftermarket braided lines consists of?
