1 - 9 of 9 Posts
Custom User Title
I've been thinking about buying a supra for a long time
If someone can either answer or direct me to a page with answers, that would be great
Just was wondering what the differences are between a normally aspirated mkiv and a twin turbo mkiv
im sure people have done the conversion, so im wondering what's involved and how much it costs
im guessing the internals might be different (high compression pistons in the NA), youd need a new ECU and wiring harness, different cylinder head, but lets say someone decides to just drop in a whole turbo motor and use a turbo ecu and wiring harness
what am i missing
thanks
- chris
differences are...
Calipers, engine has 2 turbos, ECU, tranny, rear end, driveshaft, trac control, to list the just major ones.
compression on the TT is 8.5:1 and i think N/A is 9.5:1
Cost is about $10k to do a swap with about everything you need
1st Lieutenant Team BEYAW
the TT block also oil squiters for cooling and lubing reasons
for the price TT's are selling for now, you would most likely be better off buying TT. But maybe you should start off with an NA :dunno:
1 - 9 of 9 Posts
