I'm hoping to get some opinions.
I just lost the rear on my 94tt auto. Im around 700whp on a t56. The 200mm oe torsion was lost on the 1st run with drag radials. Does anyone have experience with the osgiken lsd setup?
The reason you lost your rear prematurely is because you were on Drag radials. Just FYI. Even if you put in an OS giken, you do not want to run a manual on drag radials, You run the risk of break any rear.
I run the OSG 1.5 rear end on slicks and and dozen or more launches with no issues, and another dozen launches on drag radials before that, and holding up great so far. Approximately 715 hp or 610 to the wheels since auto transmission here as well.
title sums it up. thought that was enough trap speed to hit 12s....so many cars run ~110 mph and do mid 12s
is it my 2.2 second 60' time ?
if I launch too hard it spins and hopps. so I leave around 3500 rpm, flooring it as clutch is grabbing (no spinning or hopping)
car runs 245/50 r16...
A cool video featuring an ultra clean Supra set up for 1/2 mile racing. They said the owners name is Tho, not sure if he's on the forums but indeed a incredibly beautiful car and set up!
Hey there, just wanted to share my video of me running a 11.1 with my 98 aristo.
Got kicked off the track, apparently you need a roll bar if you run 11.50 or faster.
Wanted to share this with the 2JZ community. We finally went 6 seconds in the white car. This is no record for the platform but we are pretty proud of it. We wanted to do it using a lot of the same parts that the 2JZ Street car community uses. Like most of our customer this car still runs OEM...
