1 - 11 of 11 Posts
Bought a new dipstick tube the old one was just kind of chilling there. I assumed it was to bolt to the lower half of the intake manifold but it doesn't seem to reach anything. Does it bolt to a bracket that is bolted to the intake manifold? Can't really see it clearly in pictures or my service manual. Also went into the dealer and they couldn't tell me. I have a part number that it might be but it's non returnable. I can make a bracket but I'd like it to be Oem. Can someone a picture for me? Thanks!
Discussion Starter #2
I think maybe there is a support bracket for the intake manifold on the bottom side of the intake to the block that this bolts to. I think I am missing this support bracket. Can anyone confirm? Thanks
Master Shit Fixer
There is a bracket, and it does bolt to the intake manifold with a 10mm bolt. The "support bracket" that you are talking about in your 2nd post is a bracket with 2 vacuum pipes welded to it (for the pressure tank). I've got a picture at home that I can post tonight if no one beats me to it.
Master Shit Fixer
I think the bracket is part # 17118-46050.
that kind of looks like the correct part, hard to tell since it's just floating in the pic not where it really would go. It bolts to the block and runs parallel with the dipstick and bolts to the intake manifold. Then on the dipstick tube theres a small bracket where it bolts to this support bracket, it also has kind of a hook hanging off of it to support some wires or something.
the part bitshftr is talking about is the correct one.
the tube does bolt to the bracket. the bracket goes between the block and intake mani.
i accidentally tossed my old bracket and had to buy a new one also. stupid.
Awesome that's exactly the one I thought it was. Thanks guys.
Master Shit Fixer
Master Shit Fixer
Found my picture:
Discussion Starter #10
perfect thanks!
Discussion Starter #11
Got the bracket, it is the right one. thanks guys
1 - 11 of 11 Posts
