1 - 10 of 10 Posts
Discussion Starter · #2 ·
Somebody's got to know...
I've got a 29.35mm (1.155in) ID of the distributor hole, and a 23.93mm (.940") OD of the distributor itself (where the O ring goes)..
So am I looking for a 24mm O Ring, 5.5mm thick?
Have to order it (2 days), and they want $3.60. Screw that... ORings are generally a buck or less!
Hmm... maybe a 15/16" O ring, 1/8th" thick would do...
and have to wait another 2 days? 15/16" (.9375" - snug fit) ID and 1.1875" OD - that's .05" to squish, and be a nice, leak free seal :) And 56 cents vs 2 days wait, and 3 bucks left over?
;) Not trying to be a cheapskate, but I'm not willing to get bent over at the stealership, with their 645% markup :rolleyes:
SP74HO
Go to you local parts store, they should have a box of assorted O rings. Its a 214 or 213 Oring. If you can remove the old one with out breaking it, match it up.
I believe it a National 214. Its a bit thicker than a OEM one, but it will work! Also CHEAP!
1 - 10 of 10 Posts
