· THE LAST NA
http://www.kbox.ca/catalog/product_info.php?cPath=47&products_id=252
7MGE / 7MGTE Cam Position Sensor (CPS) Seal Kit #12313002 $24.99
Kit contents.
(1) External Housing O-ring
(1) Internal Oil Seal
(1) Internal Bearing
(1) Shaft Pin
Applications include the following vehicles but please check your specific motor prior to purchasing.
Supra MA70 January 1986 - August 1990 (8601-9008)
Supra MA70 Turbo August 1986 - May 1993 (8608-9305)
Cressida MX83 August 1988 - July 1992 (8808-9207)
I planned on changing o-ring,
if you leak oil on the cylinder head or block, you have a bad o-ring
if you have oil in the cap, you havea bad distributor......
http://cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=1902&P=1
· Overlooked
Good job pos. Go fail somewhere else.
Cooled, it would be a good idea to do the whole thing. Same thing was going on in my wifes Celica. Replaced the o-ring, then it started coming out of the cap a few weeks later. It's not that hard as long as you have a press. I think a reman distributor isn't all the expensive either.
· THE LAST NA
wow, i agree with you that the distributor can be rebuilt........So i need a press......ok......anything else.......
autozone wants $250
any [email protected]#[email protected] links? or is this a turbo forum only
