I need to know if this is illustration is correct of the intake system on the TT. I would like all the explanation that I can get. I'm new at the TT but I do have a NA but the intake is totally different than the TT's. So please help a fellow Supra bro out...
My 94TT is BPU+ and I just got a Haltech Elite 2500 to go standalone. Sticking with stock fuel (upgraded injectors though) for now, and would like to drop in a fuel-pressure sensor somewhere. Is there any easy spot to do that ? Maybe the banjo/union bolt on the existing fuel-pressure...
After I have installed all the new seals, BCsprings, retainers, locks and buckets,
with T-belt off, put crank at -10 btdc so all pistons are slightly down, install new BC 272 cams, install cam gears, torque cams as per manual. Then turn CAMS clockwise to tdc notches, and than turn CRANK to tdc...
I am about to repaint my brake calioers. I’m looking for ideas (my car is white).
Post your pics - try and show your car color - and let’s see what’s out there.
I will post after pics when I have some ideas.
Recently acquired a rhd supra and slowly starting the process of swapping things over. Got myself some glass headlights and wanted to swap bulbs while I’m at it. Been told jdm lights differ from usdm. Hard finding more info on this. Thoughts? Trying to find a quality hid system, seems LED isn’t...
