i am replacing my twins with a t78 kit this weekend with stock fuel will i need to use a different map?????
thanks
joe
· HIGH ON PSI
thanks
joe
you will definitely need to retune (i guessing you have a MAP ECU). i ran a T-78 on stock fuel on the stock map initially. only boosted in 2nd gear for a second or two and my wideband went lean in the range of 12.5-12.7. MTR's map is a good start for a single on stock fuel. its safe( rich a hell, at least for me) and you can tweak the map if you have a W/B.
36Chambers said:
I hope you don't on plan on boosting more that 16psi...
nope i plan on boosting 26psi all the time on 87 octane, the car can handle it....its a supra for god sake.....why do you post if you cant answer my question??? i know what i am doing
thanks nyc 93, where can i find MTR's map and yes i am running a map ecu with a wideband. i plan on doing a fuel upgrade soon i just want something safe for the time being
· HIGH ON PSI
im having some trouble finding the exact thread that it was on. you can PM me your email address and ill send it over to you.
