1 - 3 of 3 Posts
Guys,
Last night re-installing my upper intake manifold I broke the plunger fitting on my blue connector that connected to the turbo pressure sender. The car is a single now with a Titan fuel system and do I need these two sensors. The turbo pressure is a 3 prong clip and the other is a two prong blue clip. If I do not need then do I have to put a resistor in any of the wire connections and if so what ohm.
Thanks for the help.
Staats
The pressure sensor is not needed if you have a single turbo unless you dont have the 12V fuel pump mod done yet, the blue sensor is for rising fuel pressure on hot days i think, the pressure sensor lets the fuel pump control unit know when to switch from 9v to 12v and also other sensors to function when on stock twins.
Thanks a million!
Staats
1 - 3 of 3 Posts
