·I can't believe how expensive these are! How much RWHP can I make out of a SP-57 or a SP-63? Are small single turbos reliable or do they add extra un-needed stress on the engine!
Steve Jarvis said:Yes we do. I did it because I could add about 100rwhp on pump gas with stock MAF and fuel system. The other factor is because this turbo should actually be more reliable on the roadcourse than the stock turbo's. Just a few years ago, I thought this was crazy also. Actually I gained 94rwhp for about $5,800. This is on top of BPU+. That is actually less than $62/rwhp. Believe it or not, that is a good bargain. Think of it this way. If a FMIC will give you 20rwhp for $1,500 than you have spent $75/rwhp. Now you can see what a bargain the single turbo's really are.Of course the "MAX AIR" airbox adds around 8rwhp for $259. That is less than $33/rwhp so everyone with stock turbos should run right out and buy one.
Later, Steve
good point!Steve Jarvis said:Yes we do. I did it because I could add about 100rwhp on pump gas with stock MAF and fuel system. The other factor is because this turbo should actually be more reliable on the roadcourse than the stock turbo's. Just a few years ago, I thought this was crazy also. Actually I gained 94rwhp for about $5,800. This is on top of BPU+. That is actually less than $62/rwhp. Believe it or not, that is a good bargain. Think of it this way. If a FMIC will give you 20rwhp for $1,500 than you have spent $75/rwhp. Now you can see what a bargain the single turbo's really are.Of course the "MAX AIR" airbox adds around 8rwhp for $259. That is less than $33/rwhp so everyone with stock turbos should run right out and buy one.
Later, Steve
