I tracked my '94 TT with BPU, ETTC, and suspension for two years and my '93 MRT BPU and suspension for a few years. The MR2 with 220whp was always ~6 seconds/lap slower on a high speed track like Mosport. I've recently installed a GT28RS DBB turbo on it and at 17 psi it's become a torque monster. As I won't be able to get it out on the track until July to see how it's improved, I've been crunching the dyno numbers, and now posting here for input.
Comparing the torque from 3500-7000 rpm, it very closely matches the stock TT power, but when adjusted for the vehicle weight difference it obviously exceeds it. It actually falls half way between the power a sequential and true twin BPU TT @ 15 psi when adjusted for weight. This "area under the torque curve" power comparison doesn't take into consideration many other factors of course, so I'm curious if any others could share their Supra experiences with, or against, a turbo modified MR2 at the track.
FWIW, data logging shows very close cornering speed for the two cars so the 6 sec. difference was mostly from the straights. The new turbo spools quickly (ie 250ft-lbs by 3250 rpm), and it's transient response seems much faster than the true twins, so it's actual performance might slightly exceed what it's power band indicates.
Bruce H.
Bruce H.
