Today the supra did not want to boost properly. I hit fuel cut (or what i think is fuel cut) at about 8-9 PSI. Did a diagnostic I have a code 34(excessive turbo pressure), 51, which is the TPS. Is that excessive turbo pressure code a fancy way of saying fuel cut?
I've found the procedure to check the TPS but the Fluke meter is at my shop. I will do it tomorrow.
Now, my question is this. If I have a faulty TPS, would this be a reason why I am hitting fuel cut/code 34?? The TPS is talking to the ECU/whatever but is not giving the ECu/whatever the correct reading? hence no fuel? problem seams to happen occasionally. Was hitting 12 PSI no problem at times today, then other times she said no!
