1 - 17 of 17 Posts
I got my self a stock supra last summer.
Now its time for upgrade.
Does this look like a good kit?
Have I missed anything?
94 MKIV 6-spd.
RPS Flywheel
RPS Stage-2 Clutch
Greddy Boost Cut Controller BCC
Greddy Profec B Spec II BC (black)
Greddy Oil Filter Relocation Kit - 2JZ
Stainless Supra MKIV Turbo Downpipe
Greddy titanium cat-back
water wetter
Blits Sus intake
MAP-ECU
Greddy 93-98 Supra Strut Tower Bar
Cusco Oval Strut Tower Bar
RMM Front Lip MKIV
So.. now im broke :/
94 MKIV 6-spd.
RPS Flywheel
RPS Stage-2 Clutch
water wetter
Blits Sus intake
MAP-ECU
RMM Front Lip MKIV
lookin pretty good, man. if i were in your shoes, i'd cancel out the MAP ECU, save yourself 900 bucks, and put that towards a Greddy 3 row kit. honestly, it would do you much better than going with a MAP ECU - at that point you wouldn't have any mod's that would require A/F ratio tuning. Also, you should pick up a turbo timer as well (greddy, hks, etc.) - good to keep things safe. other than that, you're covering all the BPU mod's, which is definitely the way to go.
I see some guy's out here buying stock supra's, and immediately throwing a single turbo on them - why???? no mod's to support it, no fuel, no tune, etc.. it's only a matter of time before the engine blows.
hope that helps, man..
-jim
2jz powered
^^ i'd have to disagree with tossing the map ecu for a greddy 3 row. the stock IC has been proven to provide enough cooling for stock turbos and bolting a 3 row on will not really give you any extra hp. as with the map ecu, if you get it tuned, you can see an additional 20hp...from what powerhouse says.
On 2 wheels
How many miles are on your car? Make sure everything is running perfectly before you start modding in order to cut down on troubleshooting time if something goes wrong. IMO, I would spend a big portion of that fund on bringing everything back to spec. But hey, its not my car :dunno:
Discussion Starter #9
My car has 6089 miles on it.
Im also changing the tranny oil (orginal toyota gear oil v160).
Also this when chaninging clutch:
Toyota OEM Throw Out Bearing for 1993-98 Supra
Toyota OEM Pilot Bearing for 1993-98 Supra Twin Turbo
Toyota OEM Snap Ring (Large) for 1993-98 Supra
Toyota OEM Snap Ring (Small) for 1993-98 Supra
Should I go with ARP or OEM on the flywheel?
SUPRAS FOR LIFE
well... make sure n get a compression test done before buying...cause the car is boosted beyond the stock boost cut....i know everyone in this thread said its a pretty good start...but i was u ...i would find a supra that doesnt have a boost controller n greddy bcc!!
Discussion Starter #13
Its allready my car.. got it last summer :p
And it is still stock!
Didnt you read the thread? :scratch:
Might want to consider an oil catch can to keep your intake clean, and EGR plates to keep the last 2 (or was it 1?) cylinders cooler.
Discussion Starter #17
yes.. its 6000 miles.
can post some pictures on the steeringwheel and shiftknob :p
1 - 17 of 17 Posts
