1 - 8 of 8 Posts
J
Hey guys, something weird just happened... My car thinks the doors are open, but the doors are closed....anyone ever had a problems like this happen to them before? and if you did or didn't do you know how to fix it?
J
Discussion Starter #2
I need to fix it because the lights that say the doors are open are on and the little neon circle around the ignition is lit up...
Check both doors again, hood, and rear hatch. It also can be the muscle on your weak arms. The passengers who roll w/ me 90% of the time never get that door closed shut when they leave so I assume since you are 14 you never had a job before due from mommy spoon feeding you.
Team 10+ Year Member
Check the door lock striker (part the lock on the door grabs) make sure its tight and not moving.
J
Yea muscle on my weak arms huh? thaz why I've been doing construction work for a year now... paying my mom, yup weak arms .. O and thnx Dan94
Old School
I had this problem...I ended up never finding the solution so I just unplugged the sensor.
J
0o0o0o you had that problem also?, what did you unplug?
Old School
First, figured out the driver's side door striker in the door jam was causing the problem. So I unplugged it.
1 - 8 of 8 Posts
