1 - 20 of 148 Posts
· Captain Slow.
Well I have been searching around the forum for awhile, I know how to use the search bar derp.
so post your
Rim specs
backspacing or offset. width and height
fender/ tire wall modifications
rear tire specs
height:
section width:
tread width:
front tire specs:
also! what times you have put down with your setup. ETa, trap mph, estimated hp,tq
and any additional info you may have
Pics to go along would be nice also!
GO
· Sound Performance
this thread has amazing potential.... hopefully one day I'll be able to post my car in here
I don't know all of the answers to your question regaurding back spacing and all of that.
I have MT ET streets, 275, 45, 17's on my Work Equips. They're 26 inches tall. I have 245, 45, 17" tires on the front. All we have locally is an 1/8 mile track.
My best time so far is a 7.61 @ 97mph with a 1.75 sixty foot if I'm remembering correctly. I would like to go to a 27" ET street, but I haven't found one for a 17" wheel.
Stock subframe with LIPP traction arms and a one piece aluminum ds from Shaftmasters.
Edit: I had my best time at a 7.91 for some reason.
· Captain Slow.
good keep it coming guys!
· Captain Slow.
Discussion Starter · #10 ·
they dont make 28tall in a 16inch rim for what i have seen :(
· Flying Dutchman Pilot!
OEM MKIV rims in the front with stock sized michelin pilots, 45 psi
RX7 RD rims in the rear
MT ET Street Radial 255 50R16 26" tall:
Auto1.47 60' 9.9 @ 121 on the brakes at 1000' 3.91 Rear
R154 1.55 60' 11.50 @ 119 4.10 Rear
MT ET Street Radial 295 50R16 27.7" tall:
Auto 1.44 60' 9.78 @ 139 4.30 Rear(Rolled Fenders, massaged spring perch, required spacer, very tight)
All passes on eibochs and tokico illumina 2s at about 3700lbs, TEMS locked soft.
· Captain Slow.
Discussion Starter · #13 ·
any pictures of your setups?
· Banned
dont mix bias ply and street tires
either run a skinny up front, or run a drag radial in the rear.
· Captain Slow.
Discussion Starter · #19 ·
anybody know what the max amount of tire is that we can fit in the rear?
talk to sean from titan or vijay from big daddy they will know
1 - 20 of 148 Posts
