1 - 9 of 9 Posts
Quick question. I know the brakes use DOT3 stock, I assme the clutch does as well? I have an upgraded clutch, shound I just make the move to DOT4, anyways? It's a daily driver.
T88 YOU
dot4 is not a better/stronger fluid than 3, it will not be upgrading at all... DOT4 has a slightly higher boiling point but different characteristics as far as seal swell and such go, i would not change it from what is originally used in it. for example, DOT5 is silicon based and if mixed with dot3/4 it will make a gummy residue and harm braking performance.
T88 YOU
yes, depending on the type of dot4 you use, it could have problems mixing not only with the residual dot3 fluid but could also affect the seals in the system. i would stick with dot3 if that is in fact what the stock clutch system uses, i am not sure. if it uses dot4 then yes, go ahead and use dot4. just my .02
Supra Owner Since 1996
I believe I use Valvaline synthetic which is possibly dot 5. Just bleed your system of the old stuff.
DOT 3 or 4 will be OK. They are compatible and mix together fine. DOT 4 has a higher boil point (not needed for clutch) than DOT 3 but also has a higher moisture absorbancy rate. Valvoline synthetic is designated as DOT 5.1 fluid and is compatible with DOT 3 and DOT 4. DOT 5 is incompatible with all of the above. It is a silicone fluid and is not recommended for any application on the Supra .
just like normore said, you can mix 3 and 4 but not 5. just put dot 3 back in there, there no need to "upgrade" your clutch fluid, i doubt it will ever see high temps like your brake system does.
Thanks! I got some Valvoline synthetic since it said it's compatible with DOT3 and 4, and I plan on flushing my brake system soon as well, so I'll use it there, too.
1 - 9 of 9 Posts
